isis redistribute static
Identify routes on the local switch to be announced into the Shortest Path Bridging MAC (SPBM) network.
Syntax
Command Parameters
enable
Enables route redistribution.
metric <0-65535>
Configures the metric (cost) to apply to redistributed routes. The default is 1.
metric-type <external | internal>
Configures the type of route to import into the protocol. The default is internal.
route-map WORD<0-64>
Configures the route policy to apply to redistributed routes. Specifies a name.
subnets <allow | suppress>
Indicates whether the subnets are advertised individually or aggregated to their classful subnet. Choose allow to advertise the subnets individually with the learned or configured mask of the subnet. The default is allow.
Default
By default, redistribution is disabled.
Command Mode
VRF Router Configuration
